Query on port-heads
I believe that Colin Chapman's modification was done by the inlet manifold which had a plate protruding into the siamesed inlet ports to divide them. Then inlet manifold was double and fed in pairs 1&4 and 2&3. It used a Ford V8 Stromberg carburetor which is a double unit. Effectively 2 units fed from one float chamber. Two barrels each with their own jets running in parallel. This gives better gas flow and allows each pair to be tuned separately.
I don't know where I got this from, possibly made it up?
Query on port-heads - by Nate M - 30-04-2020, 06:30 AM
RE: Query on port-heads - by Bob Culver - 30-04-2020, 07:14 AM
RE: Query on port-heads - by Ritchie Wilson - 30-04-2020, 08:08 AM
RE: Query on port-heads - by AustinWood - 30-04-2020, 09:05 AM
RE: Query on port-heads - by Mike Costigan - 30-04-2020, 09:34 AM
RE: Query on port-heads - by Renaud - 30-04-2020, 09:52 AM
RE: Query on port-heads - by Austin in the Shed - 30-04-2020, 10:23 AM
RE: Query on port-heads - by Alan - 30-04-2020, 10:26 AM
RE: Query on port-heads - by austin - 30-04-2020, 10:37 AM
RE: Query on port-heads - by Mike Costigan - 30-04-2020, 10:50 AM
RE: Query on port-heads - by Zetomagneto - 30-04-2020, 11:35 AM
RE: Query on port-heads - by Chris KC - 30-04-2020, 11:47 AM
RE: Query on port-heads - by Henry Harris - 30-04-2020, 12:19 PM
RE: Query on port-heads - by Hugh Barnes - 30-04-2020, 01:06 PM
RE: Query on port-heads - by Robert Leigh - 30-04-2020, 01:20 PM
RE: Query on port-heads - by Chris KC - 30-04-2020, 01:31 PM
RE: Query on port-heads - by Hugh Barnes - 30-04-2020, 02:07 PM
RE: Query on port-heads - by geoffharrison - 30-04-2020, 02:16 PM
RE: Query on port-heads - by Rogerfrench - 30-04-2020, 03:31 PM
RE: Query on port-heads - by Hugh Barnes - 30-04-2020, 06:27 PM
RE: Query on port-heads - by Henry Harris - 30-04-2020, 09:15 PM
RE: Query on port-heads - by Chris KC - 30-04-2020, 10:16 PM
RE: Query on port-heads - by Hugh Barnes - 01-05-2020, 08:12 AM
RE: Query on port-heads - by Bob Culver - 01-05-2020, 09:02 AM
RE: Query on port-heads - by Nick Lettington - 01-05-2020, 02:38 PM
RE: Query on port-heads - by Rogerfrench - 01-05-2020, 04:06 PM
RE: Query on port-heads - by Lowespeed - 01-05-2020, 04:18 PM
RE: Query on port-heads - by Archivist - 01-05-2020, 05:38 PM
RE: Query on port-heads - by Nate M - 02-05-2020, 05:02 AM
RE: Query on port-heads - by Jeff Taylor - 03-05-2020, 03:02 PM
RE: Query on port-heads - by Nate M - 04-05-2020, 07:08 AM
RE: Query on port-heads - by Rogerfrench - 04-05-2020, 02:18 PM
RE: Query on port-heads - by Bob Culver - 04-05-2020, 09:46 PM
RE: Query on port-heads - by Nate M - 05-05-2020, 04:47 AM
