Steering
(28-04-2020, 10:12 PM)Youngseven Wrote: Just to confirm the drag link needs to connect on the inside of the steering box arm not outside. With the drag link is there one set Length for all sevens.
Yes, I also think that the main problem is that your drag link is too long. Can you measure it? It should be 24”, although I learnt recently that you will need to lengthen it slightly if using a wedge - can let you know later in the week by how much.
You can (and should) buy a brand new brake rod to replace the bent one.
I can see that your car was originally fitted with an hour glass steering column - these mounted to the side of the chassis only, through the two holes you can see. You can lower these without the need for a wedge by altering the rearmost hole, that ensures that the brake pedal pivot retains original position. You can only do this if you still have the original column of course.
Steering - by Youngseven - 28-04-2020, 06:23 PM
RE: Steering - by Howard Wright - 28-04-2020, 07:54 PM
RE: Steering - by Steve kay - 28-04-2020, 08:14 PM
RE: Steering - by "Slack Alice" Simon - 28-04-2020, 08:30 PM
RE: Steering - by Ruairidh Dunford - 28-04-2020, 08:43 PM
RE: Steering - by Colin Reed - 28-04-2020, 10:08 PM
RE: Steering - by Youngseven - 28-04-2020, 10:12 PM
RE: Steering - by Ian Williams - 28-04-2020, 10:19 PM
RE: Steering - by Henry Harris - 28-04-2020, 10:31 PM
RE: Steering - by Ruairidh Dunford - 28-04-2020, 10:35 PM
