Drive it Day 2020 - if you could, what and where would you drive?
#30
Sounds like a plan!
For those of you who aren't "au fait" with Mont Aigoual, it's one of the high points in the CĂ©vennes national park with an Observatory on the top. The summit tops out at 1565 metres, which isn't the highest by quite a bit (for example, Mont Ventoux is 1910 metres and the Cime de la Bonnette is 2860 metres, but nevertheless it's a good climb and the views are superb. Mont Aigoual is 100km by road from Rekkers Towers. (couple of hours)
Image here from the orientation table at the summit:
HERE
You can rotate the picture to see the whole view.
RE: Drive it Day 2020 - if you could, what and where would you drive? - by Reckless Rat - 28-04-2020, 11:27 AM
