20-04-2020, 04:55 PM
(This post was last modified: 20-04-2020, 04:58 PM by John Mason.)
Hi Hello forum readers, I am in the process of overhauling my Mk1 Ruby’s steering box as per the article on the Cornwall Austin Seven Site. I am now at the re assemble stage having thoroughly cleaned out the valve grinding paste and making sure everything moves smoothly without any play and not tight. However when I re assemble the steering arm into the end plate with a new felt oil seal washer it becomes tight to turn in the bush.It must be the felt washer as it moves freely when assembled without it. What am I doing wrong ? I assume and hope it will be something simple. I did consider assembling without it as I fill the box with GP grease and not oil.
John Mason
John Mason
