@Bob Culver
Thank you for identifying the dynamo. The dynamo field has no connection to an ignition switch. Therefore the field has no regulation by resistors. There is only a connection between the two connectors of the dynamo. I guess that is the reason for burned bulbs. Because German rules require additional equipment and the lights are a safety factor I will go for 12V with a dynamator.
@Reckless Rat
@ Ian Williams
I'm not really sure but the scuttle shows a little effect of magnetism. At this point it needs some more investigation.
@Reckless Rat
@ Ian Williams
