11-04-2020, 12:36 PM
Hello all and happy self distancing ☹️
It appears that my 7 chassis has been chopped, I don’t mind this but it brings up a couple of issues!
I want to maintain the 6ft 3” wheel base although this will mean chopping and cutting the rear of the chassis as the springs are obviously wider than the chassis when brought forward!
Another way I considered was to place the springs above the chassis on supporting brkts which I have seen!
Has anyone got any images please? Especially of how far the spring distance is from rear U bolt to the end of the chassis.
Also is there enough room for the steering track rod be moved in front of the front axle and the damper position be changed?
Don’t all shout at once?
