Block crack - is this terminal
Ah, yes I imagine that anything 'local' is several hours drive away!
It might be worth trying 'k seal' as an jn-coolant sealant. It works well to block leaksz but crucially it doesn't block radiator cores and water ways like other sealants do. Used in conjunction with a chemical metal to fill the crack from the iursidez it might just do the trick.
While I was cleaning up and inspecting an old Alvis block a month ago, I found a crack which had been filled with chewing gum - going by the amount of gunk and paint over it, was over 40 years old and had held for the pressure test!
Block crack - is this terminal - by Mark Dymond - 08-04-2020, 08:22 AM
RE: Block crack - is this terminal - by bob46320 - 08-04-2020, 08:29 AM
RE: Block crack - is this terminal - by Pete236 - 08-04-2020, 09:00 AM
RE: Block crack - is this terminal - by Geoff101 - 08-04-2020, 09:23 AM
RE: Block crack - is this terminal - by Pete236 - 08-04-2020, 09:28 AM
RE: Block crack - is this terminal - by A G Wood - 08-04-2020, 10:51 AM
RE: Block crack - is this terminal - by Pete236 - 08-04-2020, 01:14 PM
RE: Block crack - is this terminal - by Ray White - 08-04-2020, 02:14 PM
RE: Block crack - is this terminal - by Chris KC - 08-04-2020, 04:16 PM
RE: Block crack - is this terminal - by Dave Mann - 08-04-2020, 09:35 PM
RE: Block crack - is this terminal - by bob46320 - 09-04-2020, 12:40 PM
