Block crack - is this terminal
Thanks all, should have said Dad is in country Western Australia so laser welding probably not an option with current travel restrictions. Interesting to hear of good results from in-coolant sealants, tempting easy option. Ill look into getting something delivered to him. As I mentioned he says the rest of the block is in good condition but I suspect his calibration of "good" was set in the 60's when good equaled "will run" Smile
Block crack - is this terminal - by Mark Dymond - 08-04-2020, 08:22 AM
RE: Block crack - is this terminal - by bob46320 - 08-04-2020, 08:29 AM
RE: Block crack - is this terminal - by Pete236 - 08-04-2020, 09:00 AM
RE: Block crack - is this terminal - by Geoff101 - 08-04-2020, 09:23 AM
RE: Block crack - is this terminal - by Pete236 - 08-04-2020, 09:28 AM
RE: Block crack - is this terminal - by A G Wood - 08-04-2020, 10:51 AM
RE: Block crack - is this terminal - by Mark Dymond - 08-04-2020, 11:49 AM
RE: Block crack - is this terminal - by Pete236 - 08-04-2020, 01:14 PM
RE: Block crack - is this terminal - by Ray White - 08-04-2020, 02:14 PM
RE: Block crack - is this terminal - by Chris KC - 08-04-2020, 04:16 PM
RE: Block crack - is this terminal - by Dave Mann - 08-04-2020, 09:35 PM
RE: Block crack - is this terminal - by bob46320 - 09-04-2020, 12:40 PM
