05-04-2020, 06:10 PM
Hi Peter
Yes you need to remove the adjuster cover plates and unscrew the adjusters. Underneath is a wire circlip to be removed and then the felt seal should be under a cover plate. It probably should incur a full re-meshing process but perhaps if you mark the adjusters carefully it may be possible to get things back as they were? Probably a good idea to replace the felt seals with lip seals while You are at it?
