Half-shaft oil seals
Can anyone talk me through the procedure for removing and replacing half shaft oil seals on a '37 axle. It's 30 years since I last did it and can't remember!
So far I have split the axle and removed the innards. I assume the two bolts on the outside of each casing need to be removed to release the adjuster. Does this then unscrew to reveal the seal housing? and how will I manage to restore the adjustment to its original position when I reassemble? Strangely the Woodrow manual seems to gloss over this.
Peter.
Half-shaft oil seals - by Peter Naulls - 05-04-2020, 05:32 PM
RE: Half-shaft oil seals - by Howard Wright - 05-04-2020, 06:10 PM
RE: Half-shaft oil seals - by Alan - 05-04-2020, 07:21 PM
RE: Half-shaft oil seals - by Bob Culver - 05-04-2020, 08:11 PM
RE: Half-shaft oil seals - by Peter Naulls - 05-04-2020, 10:58 PM
RE: Half-shaft oil seals - by Tony Press - 06-04-2020, 12:47 AM
RE: Half-shaft oil seals - by Alan - 06-04-2020, 09:34 AM
