Chassis and axle position?
Hi I’ve been trying to get the body to line up on my rtc special (1934 ruby) I believe but I’m not really having much luck. The body seems straight on the chassis but both axles seem to be over to one side or another? I have stripped and rebuilt the rear shocks removed the springs ect and the axle is still nearly 10mm over towards the passenger side, now on the front the axle is nearly 20mm over to one side. I know this is probably a silly question but are the axles supposed to be off center? If not is the front just a question of loosening the spring u bolts and pushing it across? In the phot you can see that the drop links are both lent over. Does this look correct?
Sorry for all the questions I’m new to Austin 7’s but really do appreciate the help
Aaron
Chassis and axle position? - by Caddy1980 - 03-04-2020, 07:53 PM
RE: Chassis and axle position? - by Howard Wright - 03-04-2020, 08:31 PM
RE: Chassis and axle position? - by Caddy1980 - 03-04-2020, 08:48 PM
RE: Chassis and axle position? - by Tony Press - 04-04-2020, 01:16 AM
RE: Chassis and axle position? - by Steve kay - 04-04-2020, 09:14 AM
RE: Chassis and axle position? - by Caddy1980 - 04-04-2020, 10:21 AM
RE: Chassis and axle position? - by Howard Wright - 04-04-2020, 11:06 AM
RE: Chassis and axle position? - by Caddy1980 - 04-04-2020, 06:04 PM
