Chummy tank
Joss has a Copper Chummy tank made exactly the same way as a regular chummy tank, painted you would never know, and no doubt Brass would also work well as Henry says. When I made my tank with soldered seams I used steel sheet and tinned the base using the type of solder paste you would use when tinning a panel for lead loading, I found that it was possible to maintain control of distortion. Henrys suggestion of tin plated stainless steel is interesting, I imagine it would solder well but stainless is harder to work so it might be difficult to double clench the seams.....But then I am just an amateur shed bodger not a professional so I was probably doing it all wrong anyway.
Chummy tank - by Duncan Grimmond - 31-03-2020, 09:22 PM
RE: Chummy tank - by Duncan Grimmond - 01-04-2020, 07:03 PM
RE: Chummy tank - by Chris KC - 01-04-2020, 07:14 PM
RE: Chummy tank - by Zetomagneto - 01-04-2020, 07:52 PM
RE: Chummy tank - by Duncan Grimmond - 01-04-2020, 11:14 PM
RE: Chummy tank - by Hugh Barnes - 02-04-2020, 09:12 AM
RE: Chummy tank - by JonE - 02-04-2020, 09:54 AM
RE: Chummy tank - by Tony Press - 02-04-2020, 07:34 PM
RE: Chummy tank - by Ian Williams - 02-04-2020, 08:41 PM
RE: Chummy tank - by Duncan Grimmond - 02-04-2020, 10:59 PM
RE: Chummy tank - by Henry Harris - 02-04-2020, 11:28 PM
RE: Chummy tank - by Ian Williams - 03-04-2020, 01:26 AM
RE: Chummy tank - by Henry Harris - 03-04-2020, 09:25 AM
RE: Chummy tank - by Ivor Hawkins - 03-04-2020, 09:39 AM
RE: Chummy tank - by Colin Swinbourne - 03-04-2020, 09:58 AM
RE: Chummy tank - by Robert Foreman - 03-04-2020, 04:20 PM
RE: Chummy tank - by Duncan Grimmond - 04-04-2020, 08:43 AM
RE: Chummy tank - by Zetomagneto - 04-04-2020, 09:24 AM
RE: Chummy tank - by Duncan Grimmond - 04-04-2020, 04:50 PM
RE: Chummy tank - by Spex - 04-04-2020, 07:21 PM
RE: Chummy tank - by Ian Williams - 04-04-2020, 08:21 PM
RE: Chummy tank - by Renaud - 02-05-2020, 02:52 PM
RE: Chummy tank - by Robert Leigh - 02-05-2020, 03:52 PM
RE: Chummy tank - by Duncan Grimmond - 02-05-2020, 06:54 PM
RE: Chummy tank - by Greig Smith - 02-05-2020, 07:15 PM
RE: Chummy tank - by Duncan Grimmond - 02-05-2020, 10:50 PM
