Chummy tank
I would make it exactly like the original but Terne plate is no longer available.
Roach do them in tinplate which is the nearest equivalent but I'm not sure that tinplate would react well with water/ethanol mix.
While it's not so much the water that causes the rust, it's the oxygen that forms the ferrous oxide. I'd be tempted to tin the floor of the tank with solder but warping and buckling from the localised heat is difficult to avoid/control.
More thought required....)):-(
Chummy tank - by Duncan Grimmond - 31-03-2020, 09:22 PM
RE: Chummy tank - by Duncan Grimmond - 01-04-2020, 07:03 PM
RE: Chummy tank - by Chris KC - 01-04-2020, 07:14 PM
RE: Chummy tank - by Zetomagneto - 01-04-2020, 07:52 PM
RE: Chummy tank - by Duncan Grimmond - 01-04-2020, 11:14 PM
RE: Chummy tank - by Hugh Barnes - 02-04-2020, 09:12 AM
RE: Chummy tank - by JonE - 02-04-2020, 09:54 AM
RE: Chummy tank - by Tony Press - 02-04-2020, 07:34 PM
RE: Chummy tank - by Ian Williams - 02-04-2020, 08:41 PM
RE: Chummy tank - by Duncan Grimmond - 02-04-2020, 10:59 PM
RE: Chummy tank - by Henry Harris - 02-04-2020, 11:28 PM
RE: Chummy tank - by Ian Williams - 03-04-2020, 01:26 AM
RE: Chummy tank - by Henry Harris - 03-04-2020, 09:25 AM
RE: Chummy tank - by Ivor Hawkins - 03-04-2020, 09:39 AM
RE: Chummy tank - by Colin Swinbourne - 03-04-2020, 09:58 AM
RE: Chummy tank - by Robert Foreman - 03-04-2020, 04:20 PM
RE: Chummy tank - by Duncan Grimmond - 04-04-2020, 08:43 AM
RE: Chummy tank - by Zetomagneto - 04-04-2020, 09:24 AM
RE: Chummy tank - by Duncan Grimmond - 04-04-2020, 04:50 PM
RE: Chummy tank - by Spex - 04-04-2020, 07:21 PM
RE: Chummy tank - by Ian Williams - 04-04-2020, 08:21 PM
RE: Chummy tank - by Renaud - 02-05-2020, 02:52 PM
RE: Chummy tank - by Robert Leigh - 02-05-2020, 03:52 PM
RE: Chummy tank - by Duncan Grimmond - 02-05-2020, 06:54 PM
RE: Chummy tank - by Greig Smith - 02-05-2020, 07:15 PM
RE: Chummy tank - by Duncan Grimmond - 02-05-2020, 10:50 PM
