Re-profiling my cam followers.
If you feed it across repeatedly until it sparks out any wheel produces a fine finish eventually, and does not have to be exactly square to work. An oilstone quickly smooths.
I just marked the required centre on a smear of paint. Any error does shift the timing somewhat.
A myriad arrangemnt to avoid setting up each time present. A channel section with grubscrews thru the side to locate the follower could be attached to the faceplate and manipulated once into the correct positon.
Can remove some metal initially on a hand grinder.
RE: Re-profiling my cam followers. - by Renaud - 31-03-2020, 06:33 PM
RE: Re-profiling my cam followers. - by Bob Culver - 01-04-2020, 08:46 PM
RE: Re-profiling my cam followers. - by Jamie - 03-04-2020, 07:33 AM
RE: Re-profiling my cam followers. - by Alan - 03-04-2020, 08:51 PM
