Where do these belong?
My 20 cents worth:
E: the large 'O' rings, if they're square section and around 75-100 mm dia or bigger, I'd put money on them being [cartridge type] oil filter sealing rings, there are often several different sizes packed in with the filter element. The element can have several applications in different size housings and the unused rings tend to accumulate.
F: shackle pin or suspension/damper arm pivot kit (2 x pins and 4 x bushes)?
I've spent a bit of time on Minors in a previous life, and although they do look semi-familiar, I can't quite place where they would be found though.
Where do these belong? - by Peter Naulls - 29-03-2020, 08:39 PM
RE: Where do these belong? - by Mike Costigan - 29-03-2020, 10:00 PM
RE: Where do these belong? - by Tony Press - 30-03-2020, 01:37 AM
RE: Where do these belong? - by A G Wood - 30-03-2020, 02:01 AM
RE: Where do these belong? - by Peter Naulls - 30-03-2020, 08:29 AM
