Where do these belong?
Bearing A could be SKF RLS 11 - 1 3/8" bore - are you sure of the OD which should be 3" ? But it is not an Austin 7 Bearing.
Bearing B is SKF RMS 8 - Austin 7 Pinion Shaft Gear End 1929-35 and 3 Speed Box 3rd Motion Shaft bearing 1923-32.
Bearing C is SKF RLS 6 - Austin 7 Front Hub Outer Bearing all models.
Where do these belong? - by Peter Naulls - 29-03-2020, 08:39 PM
RE: Where do these belong? - by Mike Costigan - 29-03-2020, 10:00 PM
RE: Where do these belong? - by Tony Press - 30-03-2020, 01:37 AM
RE: Where do these belong? - by A G Wood - 30-03-2020, 02:01 AM
RE: Where do these belong? - by Peter Naulls - 30-03-2020, 08:29 AM
