  • 1 Vote(s) - 4 Average
Doug Woodrow Austin Seven Manual..
A few more examples from ebay of mundane A7 stuff from a prolific seller, at 'lunar'tic prices (clue here to the name!):
Set of valve springs £79.99 (cherished supplier £7.20)
Set of cylinder head flat washers £5.99 (cs £1.50)
Drain tap £51.99 (£29.40)
Centre main lockwasher £4.99 (72p)
Spade key £4.99 (£1.08)
Set of clutch toggle pins £5.99 (£1.68)
Set of brass manifold nuts £15.00 (£6.30)
Kingpin thrust washer £2.99 (48p)
Flywheel lockwasher £3.99 (66p)
etc. etc. etc. Mind you, some of them do include postage!
Doug Woodrow Austin Seven Manual.. - by Albert S - 05-12-2017, 03:20 PM
RE: Doug Woodrow Austin Seven Manual.. - by Erich - 05-12-2017, 05:35 PM
RE: Doug Woodrow Austin Seven Manual.. - by bystander - 05-12-2017, 08:59 PM
RE: Doug Woodrow Austin Seven Manual.. - by Alan - 06-12-2017, 12:35 PM
RE: Doug Woodrow Austin Seven Manual.. - by JohnD - 06-06-2024, 02:46 PM
