04-12-2017, 09:39 PM
From the amount of fur exhibited all over the area around the coupling, and the shiny surface of the perimeter I would say the coupling was rubbing on the handbrake ratchet or floor until clearance was obtained. The resultant heat causing the de-lamination failure.
I am not convinced the rivets in this photo have created sufficient deflection to be a worry. cheers Russell
