fettling trackrod ends... advice please
One thing to watch Jon, is when you put it all back together is that it helps to hold each track rod in position using a stillson or a mole grip to prevent it rotating while you tighten the nut on the end. An extra pair of hands can help. The Bearded Wizard and I found this out when we were trying to eliminate a tight spot on his Pearl steering when he passed this way some time back. Any strain on the track rod causes tightness in the steering. Shim out any vertical movement of the TRE if there is any without it being over tight.
fettling trackrod ends... advice please - by JonE - 24-03-2020, 03:32 PM
RE: fettling trackrod ends... advice please - by Reckless Rat - 24-03-2020, 04:23 PM
