(22-03-2020, 03:34 PM)AustinWood Wrote: On Friday I overhauled the starting handle system.
Mine is the early coil design which leaves something to be desired. It uses a sort of dog coupling which, when worn, tends to throw the handle out of mesh when turning the engine...
I used to put a slight undercut on the dog-faces which cured the problem and provided a secure engagement.
RE: What have you done today with your Austin Seven - by Mike Costigan - 22-03-2020, 03:49 PM
Users browsing this thread: 17 Guest(s)
