King pins or wheel bearings
Tony's comment "They are rather over-sized for the job." doesn't just apply to the hub bearings. Some years ago our modern with a turbo charged 2 litre diesel engine suffered a clutch release bearing failure. The garage phoned me to tell me they'd dismantled it and did I want to see it. I went with a clean Seven clutch release bearing in my pocket. and they showed me the wreckage, then I showed them a proper man sized bearing, it was over twice the size. The fitters couldn't believe it was for my Seven which they knew well after it had towed the modern in on two occasions.
King pins or wheel bearings - by John Mason - 18-03-2020, 02:59 PM
RE: King pins or wheel bearings - by Parazine - 18-03-2020, 04:59 PM
RE: King pins or wheel bearings - by AustinWood - 18-03-2020, 04:59 PM
RE: King pins or wheel bearings - by Tony Press - 19-03-2020, 02:23 AM
RE: King pins or wheel bearings - by Bob Culver - 19-03-2020, 05:40 AM
RE: King pins or wheel bearings - by John Mason - 19-03-2020, 10:09 AM
RE: King pins or wheel bearings - by Dave Mann - 21-03-2020, 10:33 AM
RE: King pins or wheel bearings - by Tony Press - 22-03-2020, 02:01 AM
