King pins or wheel bearings
The front wheel bearings are plain ball bearings with normal internal clearance so will always have a little movement even from new.
They are rather over-sized for the job so wear is unusual, but the inner bearing is sometimes loose in the hub assembly.
If you are replacing them use double sealed bearings.
King pins or wheel bearings - by John Mason - 18-03-2020, 02:59 PM
RE: King pins or wheel bearings - by Parazine - 18-03-2020, 04:59 PM
RE: King pins or wheel bearings - by AustinWood - 18-03-2020, 04:59 PM
RE: King pins or wheel bearings - by Tony Press - 19-03-2020, 02:23 AM
RE: King pins or wheel bearings - by Bob Culver - 19-03-2020, 05:40 AM
RE: King pins or wheel bearings - by John Mason - 19-03-2020, 10:09 AM
RE: King pins or wheel bearings - by Dave Mann - 21-03-2020, 10:33 AM
RE: King pins or wheel bearings - by Tony Press - 22-03-2020, 02:01 AM
