Axle Shaft Key
I made up 2 new keys today from 3/16" Ground Stock flat bar. Fortunately the key way in both the shaft and hub were in good condition. As best as I could measure the root radius machined in the shaft is 1.5" radius x 0.250" deep. I made the length 2 3/4". The key way in the hub is 1/16" therefore I made the key height 5/16" less 0.010" to make sure the key does not hold the hub off the shaft when tightened.
Tod
Axle Shaft Key - by Tod - 14-03-2020, 09:37 PM
RE: Axle Shaft Key - by John Raeburn - 15-03-2020, 07:59 AM
RE: Axle Shaft Key - by Tod - 15-03-2020, 09:19 AM
RE: Axle Shaft Key - by Bob Culver - 15-03-2020, 10:01 AM
RE: Axle Shaft Key - by Tod - 15-03-2020, 11:22 AM
RE: Axle Shaft Key - by dickie65 - 15-03-2020, 01:48 PM
RE: Axle Shaft Key - by Tod - 15-03-2020, 03:53 PM
RE: Axle Shaft Key - by Colin Wilks - 16-03-2020, 11:45 PM
RE: Axle Shaft Key - by Howard Wright - 17-03-2020, 08:37 AM
RE: Axle Shaft Key - by Duncan Grimmond - 17-03-2020, 09:26 AM
RE: Axle Shaft Key - by Colin Wilks - 17-03-2020, 10:54 AM
RE: Axle Shaft Key - by Peter Sweeney - 17-03-2020, 03:17 PM
RE: Axle Shaft Key - by Bob Culver - 18-03-2020, 12:29 AM
RE: Axle Shaft Key - by Henry Harris - 18-03-2020, 01:21 AM
RE: Axle Shaft Key - by Tod - 18-03-2020, 07:03 PM
