18-03-2020, 06:02 PM
If it is the same as my Ruby once the bottom clamp has been removed you can pull it out as described by Parazine until it is clear of the steering wheel then if working from below the steering wheel remove the three small nut that hold it to the inner column. Remember to disconnect the indicator and horn connections from under the bonnet.
John Mason.
John Mason.
