King pins or wheel bearings
Wheel bearing play shows up with movement evident between the brake drum and the dust plate.
Play associated with the king pins is more often a worn axle eye and shows up with movement evident between the stub axle and the axle beam.
King pins or wheel bearings - by John Mason - 18-03-2020, 02:59 PM
RE: King pins or wheel bearings - by Ruairidh Dunford - 18-03-2020, 03:10 PM
RE: King pins or wheel bearings - by Parazine - 18-03-2020, 04:59 PM
RE: King pins or wheel bearings - by AustinWood - 18-03-2020, 04:59 PM
RE: King pins or wheel bearings - by Tony Press - 19-03-2020, 02:23 AM
RE: King pins or wheel bearings - by Bob Culver - 19-03-2020, 05:40 AM
RE: King pins or wheel bearings - by John Mason - 19-03-2020, 10:09 AM
RE: King pins or wheel bearings - by Dave Mann - 21-03-2020, 10:33 AM
RE: King pins or wheel bearings - by Tony Press - 22-03-2020, 02:01 AM
