trafficator switch/ horn push
If this is on your Big 7, the clamp is right at the bottom of the steering box, in the engine bay. Releasing this will allow the switch, complete with the supporting inner tube to be released from the column. You may need to open the sunroof to get it out, or lower the column if there is no sunroof. Good luck!
RE: trafficator switch/ horn push - by Parazine - 18-03-2020, 10:56 AM
RE: trafficator switch/ horn push - by John Mason - 18-03-2020, 06:02 PM
