Full Girling rear brakes
Ruairidh's photo of an installation on a special shows the for and aft rod passing thru a block on the rear crossmember and relying on flex in the rod for up and down travel of the axle.
In the factory arrangement there is a slave arm pointing upward in this location linking 2 halves of the same rod. Possibly not required on a special with limited axle movement.
Full Girling rear brakes - by Winston Teague - 17-03-2020, 06:04 PM
RE: Full Girling rear brakes - by Ian Williams - 17-03-2020, 07:53 PM
RE: Full Girling rear brakes - by Charles P - 17-03-2020, 08:13 PM
RE: Full Girling rear brakes - by Winston Teague - 17-03-2020, 08:36 PM
RE: Full Girling rear brakes - by Mike Costigan - 17-03-2020, 09:28 PM
RE: Full Girling rear brakes - by Winston Teague - 17-03-2020, 09:34 PM
RE: Full Girling rear brakes - by Henry Harris - 17-03-2020, 09:38 PM
RE: Full Girling rear brakes - by Winston Teague - 17-03-2020, 09:47 PM
RE: Full Girling rear brakes - by squeak - 18-03-2020, 02:05 AM
RE: Full Girling rear brakes - by Robert Leigh - 18-03-2020, 12:59 PM
RE: Full Girling rear brakes - by spannerman - 18-03-2020, 01:15 PM
