Full Girling rear brakes
I binned the cross shaft & coupled handbrake and used a cable system operated by an uncoupled type handbrake, mounted backwards (push forward to operate). Works well.
Morris Minor van cables fitted well and had the right fixings for the wheel cylinders. Simple balance beam and threaded adjustment at the front where the cables end.
C
Full Girling rear brakes - by Winston Teague - 17-03-2020, 06:04 PM
RE: Full Girling rear brakes - by Ian Williams - 17-03-2020, 07:53 PM
RE: Full Girling rear brakes - by Charles P - 17-03-2020, 08:13 PM
RE: Full Girling rear brakes - by Winston Teague - 17-03-2020, 08:36 PM
RE: Full Girling rear brakes - by Mike Costigan - 17-03-2020, 09:28 PM
RE: Full Girling rear brakes - by Winston Teague - 17-03-2020, 09:34 PM
RE: Full Girling rear brakes - by Henry Harris - 17-03-2020, 09:38 PM
RE: Full Girling rear brakes - by Winston Teague - 17-03-2020, 09:47 PM
RE: Full Girling rear brakes - by squeak - 18-03-2020, 02:05 AM
RE: Full Girling rear brakes - by Robert Leigh - 18-03-2020, 12:59 PM
RE: Full Girling rear brakes - by spannerman - 18-03-2020, 01:15 PM
