17-03-2020, 06:04 PM
Hi all, i'm up to my neck in a brake redesign on Patrick's Ulster project. The system will be mainly hydraulic, but i'm considering using the rod operated girling actuators i have, for the handbrake. I have a wiffle tree, rods, actuators from a late Ruby axle. What i'd like to see is a picture of the cross shaft end of this mechanism. There must be an upwards pointing lever on the cross shaft, to one side of the propshaft? Do any of you good folk have access to this area of the gubbins for a general arrangement photo? The cross shaft assembly in the chassis (at the moment) is an early ish coupled system, it is a late 1930 chassis. W
