Rear and side glass
There is a bit of a knack to fitting the glass and seals, apart from the need for another pair of hands. It is a long time since I did it, but you need to fit the seal to the glass and hold it in place with a string all round behind the lip which finally settles against the body. One person offers up the assembly from inside the car while the other gently pulls the string to get the lip to settle around the rim of the body hole. I have found it useful to hold the thing in place with some small home-made aluminium clips screwed to the woodwork to hold the rubber channel in place. After this you can fit the inner covered plywood surround, again using the string method to get the rubber into its proper position. Sorry I do not have a video of this! Good luck.
Robert Leigh
Rear and side glass - by Hentzant - 11-03-2020, 05:34 PM
RE: Rear and side glass - by Lowespeed - 11-03-2020, 05:59 PM
RE: Rear and side glass - by Hentzant - 11-03-2020, 06:40 PM
RE: Rear and side glass - by Reckless Rat - 11-03-2020, 08:19 PM
RE: Rear and side glass - by Robert Leigh - 11-03-2020, 08:21 PM
RE: Rear and side glass - by Hentzant - 11-03-2020, 09:01 PM
RE: Rear and side glass - by Steve kay - 12-03-2020, 08:34 AM
RE: Rear and side glass - by Howard Wright - 12-03-2020, 09:05 AM
RE: Rear and side glass - by Greig Smith - 12-03-2020, 11:16 AM
