KING PIN THRUST WASHERS
[quote pid='4144' dateline='1512143218']
Thanks Stuart.  Looks like phosphor bronze to use.  Just got to find a 1 1/6  (7mm) cutter to clean up the recessed face under the end of the axle beam.  The one I had made to do the grinding is 1 1/4 in dia. - good for the 3 other faces.  Perhaps I will just pluck up courage and try and turn it down smaller
Dennis
[/quote]
Whoops should have read 1 1/16 inch (27mm) cutter.
KING PIN THRUST WASHERS - by Dennis Nicholas - 28-11-2017, 01:55 PM
RE: KING PIN THRUST WASHERS - by Mike Costigan - 28-11-2017, 03:57 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 29-11-2017, 11:29 AM
RE: KING PIN THRUST WASHERS - by Alan - 29-11-2017, 11:49 AM
RE: KING PIN THRUST WASHERS - by Chris KC - 29-11-2017, 11:55 AM
RE: KING PIN THRUST WASHERS - by Jeff Taylor - 29-11-2017, 01:18 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 30-11-2017, 12:40 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 30-11-2017, 03:40 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 30-11-2017, 04:44 PM
RE: KING PIN THRUST WASHERS - by Stuart Giles - 30-11-2017, 05:16 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 30-11-2017, 06:23 PM
RE: KING PIN THRUST WASHERS - by Jeff Taylor - 30-11-2017, 06:02 PM
RE: KING PIN THRUST WASHERS - by Stuart Giles - 01-12-2017, 01:23 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 01-12-2017, 04:46 PM
RE: KING PIN THRUST WASHERS - by Dennis Nicholas - 02-12-2017, 11:48 AM
