SU Float Chambers
Bob is the HS2 a modern Mini type or an earlier type with the hole through the centre of the float?
 Sounds like the fuel level in the bowl could be the issue. Check fuel level by looking down the jet (level should be just below the bridge) with the dashpot and needle removed and/or set the float level according to the type of HS2 you have. I have also had issues with new replacement needle and seats both sticking and flooding.
SU Float Chambers - by bobthompson - 03-03-2020, 07:14 PM
RE: SU Float Chambers - by Alan - 03-03-2020, 07:23 PM
RE: SU Float Chambers - by bobthompson - 03-03-2020, 10:09 PM
RE: SU Float Chambers - by wild_willy - 03-03-2020, 11:54 PM
RE: SU Float Chambers - by Tony Press - 04-03-2020, 02:45 AM
RE: SU Float Chambers - by Howard Wright - 04-03-2020, 09:07 AM
RE: SU Float Chambers - by AustinWood - 04-03-2020, 11:20 AM
RE: SU Float Chambers - by Terrytuned - 04-03-2020, 06:23 PM
RE: SU Float Chambers - by bobthompson - 04-03-2020, 06:54 PM
RE: SU Float Chambers - by Howard Wright - 04-03-2020, 07:10 PM
RE: SU Float Chambers - by Paul N-M - 06-03-2020, 07:50 AM
RE: SU Float Chambers - by Rogerfrench - 06-03-2020, 03:08 PM
RE: SU Float Chambers - by Mark R - 01-04-2020, 04:04 PM
RE: SU Float Chambers - by Terrytuned - 01-04-2020, 07:31 PM
RE: SU Float Chambers - by Mark R - 01-04-2020, 08:59 PM
