It's a bit like a full dress rehearsal. Go through everything as best you can, finish with it recorded and send the image up to the Editing Suite, relax. Then not long afterwards, notes from the director, or is Ruairidh the choreographer?  "Wonderful, looks good... But can we just do it again, from the top, completely different methods and above all, no blue lube!" OK, hope this is what was intended, have to say that it does look much better and was far more convincing to assemble. So yes, surfaces on the crankcase and the sump utterly clean and dry, that's the way to do it. And thanks to Jamie who managed to pull a fresh and properly shaped gasket out of his magician's hat.
RE: What have you done today with your Austin Seven - by Steve kay - 27-02-2020, 09:05 PM
Users browsing this thread: 24 Guest(s)
