Austin 7 Trials Special
#38
Yes, the brake pedal (if using the original set-up) goes through the wedge.
I welded an extra strip downwards from the wedge, with a hole in it so I could bolt it through the old brake pivot hole.
This gives a three point mounting which helps support the column on its wedge and saves the body strut under the dash from doing a lot of work.
If you only need a small amount:  my first go at this involved making a wedge from 6mm ali which was in effect a thick washer on the main wedge's rear mount, between wedge and chassis.
I think this gave me about an extra inch or so under the wheel, which was all I needed at that time, and was crude but reasonably solid because of my third bolt as described.
Austin 7 Trials Special - by Pjkpjk - 19-02-2020, 08:49 PM
RE: Austin 7 Trials Special - by Ian Williams - 19-02-2020, 10:11 PM
RE: Austin 7 Trials Special - by Pjkpjk - 19-02-2020, 10:17 PM
RE: Austin 7 Trials Special - by Ian Williams - 19-02-2020, 10:23 PM
RE: Austin 7 Trials Special - by Pjkpjk - 19-02-2020, 10:26 PM
RE: Austin 7 Trials Special - by Mike Costigan - 20-02-2020, 09:29 AM
RE: Austin 7 Trials Special - by Howard Wright - 20-02-2020, 11:17 AM
RE: Austin 7 Trials Special - by bystander - 20-02-2020, 11:54 AM
RE: Austin 7 Trials Special - by Andrew Wilson - 20-02-2020, 01:12 PM
RE: Austin 7 Trials Special - by Jays - 20-02-2020, 05:40 PM
RE: Austin 7 Trials Special - by Alan - 20-02-2020, 06:56 PM
RE: Austin 7 Trials Special - by Pjkpjk - 20-02-2020, 09:29 PM
RE: Austin 7 Trials Special - by Reckless Rat - 20-02-2020, 09:40 PM
RE: Austin 7 Trials Special - by Pjkpjk - 20-02-2020, 09:41 PM
RE: Austin 7 Trials Special - by Dave Prior - 20-02-2020, 10:00 PM
RE: Austin 7 Trials Special - by Pjkpjk - 20-02-2020, 10:13 PM
RE: Austin 7 Trials Special - by JonE - 21-02-2020, 08:21 PM
RE: Austin 7 Trials Special - by Ian Williams - 21-02-2020, 08:40 PM
RE: Austin 7 Trials Special - by Pjkpjk - 21-02-2020, 08:46 PM
RE: Austin 7 Trials Special - by Nick Lettington - 21-02-2020, 09:19 PM
RE: Austin 7 Trials Special - by Ian Williams - 21-02-2020, 09:36 PM
RE: Austin 7 Trials Special - by Nick Lettington - 21-02-2020, 10:08 PM
RE: Austin 7 Trials Special - by Paul N-M - 22-02-2020, 03:02 PM
RE: Austin 7 Trials Special - by Pjkpjk - 22-02-2020, 04:55 PM
RE: Austin 7 Trials Special - by Steve Jones - 22-02-2020, 05:23 PM
RE: Austin 7 Trials Special - by Pjkpjk - 22-02-2020, 05:34 PM
RE: Austin 7 Trials Special - by Mike Costigan - 22-02-2020, 05:57 PM
RE: Austin 7 Trials Special - by Steve Jones - 22-02-2020, 06:06 PM
RE: Austin 7 Trials Special - by Pjkpjk - 22-02-2020, 06:22 PM
RE: Austin 7 Trials Special - by bystander - 22-02-2020, 07:20 PM
RE: Austin 7 Trials Special - by Howard Wright - 22-02-2020, 07:23 PM
RE: Austin 7 Trials Special - by Nick Lettington - 22-02-2020, 07:50 PM
RE: Austin 7 Trials Special - by Steve Jones - 22-02-2020, 08:01 PM
RE: Austin 7 Trials Special - by Pjkpjk - 22-02-2020, 08:08 PM
RE: Austin 7 Trials Special - by "Slack Alice" Simon - 22-02-2020, 08:15 PM
RE: Austin 7 Trials Special - by Ian Williams - 22-02-2020, 08:27 PM
RE: Austin 7 Trials Special - by Reckless Rat - 22-02-2020, 09:10 PM
RE: Austin 7 Trials Special - by Stumpi - 24-02-2020, 08:15 PM
RE: Austin 7 Trials Special - by Greig Smith - 24-02-2020, 09:30 PM
RE: Austin 7 Trials Special - by Ruairidh Dunford - 24-02-2020, 10:01 PM
RE: Austin 7 Trials Special - by Mike Costigan - 25-02-2020, 09:19 AM
RE: Austin 7 Trials Special - by Ruairidh Dunford - 25-02-2020, 10:05 AM
RE: Austin 7 Trials Special - by JonE - 25-02-2020, 11:54 AM
RE: Austin 7 Trials Special - by Steve Jones - 25-02-2020, 12:22 PM
RE: Austin 7 Trials Special - by Nick Salmon - 25-02-2020, 01:49 PM
RE: Austin 7 Trials Special - by Mike Costigan - 25-02-2020, 02:58 PM
