14-08-2017, 06:19 PM
(13-08-2017, 09:13 PM)Timothy P Wrote: I have made the advised changes to the plugin (A new skill I never knew I needed).
Should be attached below, Instructions as per original Install instructions in the folder.
In the thread HERE, users noted problems with the edit button not allowing editing of the event, only the thread. I assume, that this is necessary so that if the wrong date has been used or needs to be edited to recurring. They mention a number of things/changes which may or may not be and then link to THIS THREAD as a tool that solved the problem. Hope this makes some sense, and hope that it all works.
All the best
EDIT: Appears I didn't do all that was required as compatibility needed changing as well for the change from 1.6 to 1.8.
I have updated the attachment, and hopefully this will work. Let me know how you get on.
Well done you I will consult with the European side of the management team - in case impossibly you found something the managements didn't !
