Seat cushions
It is possible to cut inner tubes and seal the cut ends. This gives you more layout options and means you can inflate an outer 3-sided tube separately from the complete inner one - a bit like the original.
After cutting to length clean the inside of the tube with thinners and run super glue around the inside. Clamp together for a couple of minutes (I used a couple of small wooden battens and a G-clamp) and you'll have a permanent airtight seal.
I made mine about 4 years ago and they've never needed re-inflating.
Car inner tubes are a bit thick and some thought has to be given to the position of any folds so they don't create lumps and bumps.
Peter.
Seat cushions - by Robert Leigh - 20-02-2020, 04:46 PM
RE: Seat cushions - by Martin Baker - 20-02-2020, 06:12 PM
RE: Seat cushions - by Robert Leigh - 20-02-2020, 06:39 PM
RE: Seat cushions - by JonE - 20-02-2020, 07:48 PM
RE: Seat cushions - by Martin Baker - 20-02-2020, 08:10 PM
RE: Seat cushions - by Robert Leigh - 21-02-2020, 11:33 AM
RE: Seat cushions - by Steve Jones - 21-02-2020, 12:05 PM
RE: Seat cushions - by JonE - 21-02-2020, 02:19 PM
RE: Seat cushions - by Steve Jones - 21-02-2020, 02:46 PM
RE: Seat cushions - by spannerman - 21-02-2020, 05:58 PM
RE: Seat cushions - by Peter Naulls - 21-02-2020, 09:52 PM
RE: Seat cushions - by Steve Jones - 22-02-2020, 04:47 PM
RE: Seat cushions - by Erich - 22-02-2020, 09:16 PM
RE: Seat cushions - by Steve Jones - 22-02-2020, 10:09 PM
RE: Seat cushions - by Erich - 23-02-2020, 08:20 PM
