18-02-2020, 05:02 PM
Hi, it is easy to run a hidden wire (in the wiring loom) connected to the ignition wire running from the coil to the distributor. This wire can then be grounded via a simple on/off switch hidden under the dash....when grounded this will stop the HT to the plugs. When I get my car back on the road I will get a motorbike chain lock and secure through front axle wheel.
