Crankshaft clearances
Hi All
Sorry for posting several threads on my engine build but new questions come up as I continue. I have the 1 1/2 crank and Nippy rods assembled (trial assembly) in the case and I think everything turns without hitting anything.  I will fit trial fit the block and pistons in due course for a more accurate check.
But by how much should everything clear things.  For example in another thread Parazine suggests 3/32” as a gap between the crank and middle cam bearing.  Currently I have 50 thou!!
I have even less between the button head big end caps and the camshaft but this is more difficult to measure until I get the block and pistons in place.
I was originally working on the assumption that the oft quoted 20 thou for crank whip would be a good start (my 1 1/2 crank shouldn’t whip by this much!)
Advice please
Crankshaft clearances - by Howard Wright - 11-02-2020, 05:47 PM
RE: Crankshaft clearances - by Chris KC - 11-02-2020, 07:49 PM
RE: Crankshaft clearances - by Charles P - 11-02-2020, 08:11 PM
RE: Crankshaft clearances - by Alan - 11-02-2020, 09:33 PM
RE: Crankshaft clearances - by Spex - 12-02-2020, 12:38 AM
RE: Crankshaft clearances - by Howard Wright - 12-02-2020, 08:37 AM
RE: Crankshaft clearances - by Chris KC - 12-02-2020, 08:48 AM
RE: Crankshaft clearances - by Terrytuned - 12-02-2020, 12:16 PM
RE: Crankshaft clearances - by Chris KC - 12-02-2020, 12:20 PM
RE: Crankshaft clearances - by Alan - 12-02-2020, 01:32 PM
RE: Crankshaft clearances - by Charles P - 12-02-2020, 02:39 PM
