Differential stuck in axle housing
Of course it may just be stuck but this underlines a point I am wont to make which is that Loctite is the devil's work and should only be used with careful forethought. If it is Loctited you'll possibly need to get the thing up to a couple of hundred degrees and this can easily render useless the parts one is trying to get at.
Anyway it is time to lay down that hammer and think. It occurs to me that possibly some sort of puller might be fashioned which made use of the crown wheel mounting bolts?
RE: Differential stuck in axle housing - by Chris KC - 09-02-2020, 08:55 AM
