Wiper motor
The wiper motor should run sufficiently well to clear the rain in most conditions. My RP saloon has a replacement Bosch motor in place of the original vacuum Trico. Like your motor, this suddenly stopped working due to congealed grease in the gearbox. Check to make sure that the motor bearings (they are likely to be bronze bushes) are also lubricated and that the brushes and commutator are clean and in good order. Once I had replaced the gearbox grease and put a spot of oil on the motor bearings it didn't half pick up speed!
Wiper motor - by Merlin0161 - 08-02-2020, 08:32 PM
RE: Wiper motor - by David Stepney - 08-02-2020, 10:58 PM
