06-02-2020, 11:35 PM
From your picture Steve it looks as though the silencer body is too long and the bracket too short. On my car there is just enough room to fit the tail pipe through the rear cross member and push it back as far as it will go. Then the inlet pipe at the front will just fit through the front cross member.
On my RK I had the tail pipe turned outwards initially but found it sucked exhaust fumes in, even when extended well into the airstream. RK doors tend not to fit too well! Now with it tucked underneath I don't get fumes in the car.
