Scrap block?
The little crack is often a source of a leak which manifest itself by allowing water to go up the centre stud.
It is often thought the head gasket has failed when this happens.
I have used gasket goo under the washer on the centre stud to stop the leak as a tempory measure.
Tempory as in the same block in use for 20 years until a crack appeared in the side of number one cylinder that is. ( block was + 080 thou )
Scrap block? - by Howard Wright - 03-02-2020, 01:12 PM
RE: Scrap block? - by leaf200 - 03-02-2020, 01:47 PM
RE: Scrap block? - by Howard Wright - 03-02-2020, 02:14 PM
RE: Scrap block? - by steve anderson - 03-02-2020, 02:19 PM
RE: Scrap block? - by Chris KC - 03-02-2020, 03:00 PM
RE: Scrap block? - by Terrytuned - 03-02-2020, 03:04 PM
RE: Scrap block? - by Zetomagneto - 03-02-2020, 06:09 PM
RE: Scrap block? - by Howard Wright - 03-02-2020, 07:28 PM
RE: Scrap block? - by Tony Betts - 03-02-2020, 09:43 PM
RE: Scrap block? - by David Witton - 03-02-2020, 09:48 PM
RE: Scrap block? - by Zetomagneto - 03-02-2020, 11:54 PM
RE: Scrap block? - by dickie65 - 05-02-2020, 07:01 PM
