Big end nuts
Howard, can you put the bolts in the other way round, and use a K nut self Locking nut at the top, they are all metal self Locking with a greatly reduced head used in many motor sport applications.
I had thought about tapping the rod M9 and using ARP formula V bolts part no ARP 104 -6005
a google search will give you under head dimension.
Tapping size for M9 is 7.75 I have not got round to taking this any further but will have to address it at some future point.
I think the size between lobes on the Camshaft can be .620"  I wouldn't want to go any less than the diameter of the centre bearing
All the best
Gene
Bob, Nippy rods have a scalloped joint! A jig would have to be made up to tap these as you only have half a hole at entry
Big end nuts - by Howard Wright - 07-01-2020, 09:03 PM
RE: Big end nuts - by Ruairidh Dunford - 07-01-2020, 09:39 PM
RE: Big end nuts - by Chris KC - 07-01-2020, 11:42 PM
RE: Big end nuts - by Colin Reed - 08-01-2020, 02:44 AM
RE: Big end nuts - by Stuart Giles - 08-01-2020, 03:05 PM
RE: Big end nuts - by Colin Wilks - 08-01-2020, 05:44 PM
RE: Big end nuts - by Zetomagneto - 08-01-2020, 06:31 PM
RE: Big end nuts - by Alan - 08-01-2020, 06:51 PM
RE: Big end nuts - by Chris KC - 08-01-2020, 09:39 PM
RE: Big end nuts - by Howard Wright - 09-01-2020, 08:35 AM
RE: Big end nuts - by Howard Wright - 04-02-2020, 07:21 PM
RE: Big end nuts - by Chris KC - 04-02-2020, 08:27 PM
RE: Big end nuts - by Hugh Barnes - 04-02-2020, 09:11 PM
RE: Big end nuts - by Howard Wright - 04-02-2020, 09:44 PM
RE: Big end nuts - by Ruairidh Dunford - 04-02-2020, 10:03 PM
RE: Big end nuts - by Howard Wright - 04-02-2020, 10:36 PM
RE: Big end nuts - by Colin Wilks - 04-02-2020, 10:46 PM
RE: Big end nuts - by Bob Culver - 04-02-2020, 10:58 PM
RE: Big end nuts - by Charles P - 04-02-2020, 11:43 PM
RE: Big end nuts - by Zetomagneto - 05-02-2020, 10:45 AM
RE: Big end nuts - by Bob Culver - 05-02-2020, 07:58 PM
RE: Big end nuts - by Howard Wright - 06-02-2020, 08:52 AM
RE: Big end nuts - by Chris KC - 06-02-2020, 10:36 AM
RE: Big end nuts - by Colin Wilks - 07-02-2020, 10:52 AM
RE: Big end nuts - by Colin Wilks - 07-02-2020, 06:27 PM
RE: Big end nuts - by Howard Wright - 07-02-2020, 07:36 PM
RE: Big end nuts - by David.H - 07-02-2020, 11:32 PM
