Dynamo Advice Needed
The situaaion with the D and F connected but not externally to the battery must be avoided (except for brief voltage  test of dynamo operation). Best not to join directly on the dynamo in case output lead ever detaches. With the original DEL this condition exists. Persons thinking they were disabling the dynamo possibly accounted for burned out resistors.
There is nothing inherently wrong with the DEL, although some suggest its safe output may be slightly reduced, 8 amps on meter) The armature internal connections are different and testing by comparing adjacent segments does not apply.
Dynamo Advice Needed - by rogersirs - 04-02-2020, 05:27 PM
RE: Dynamo Advice Needed - by Bob Culver - 04-02-2020, 08:55 PM
RE: Dynamo Advice Needed - by rogersirs - 04-02-2020, 11:10 PM
RE: Dynamo Advice Needed - by Bob Culver - 05-02-2020, 06:00 AM
