04-02-2020, 11:25 PM
(04-02-2020, 09:32 AM)Hugh Barnes Wrote: For the lapping compound, you might like to consider 'Timesaver' as recommended by Hedd Jones of this Parish (IIRC) and sold by Adam Brown (also of this Parish) through Craftmaster Paints. The advantage of this medium is it doesn't hang around and continue to abrade but slowly disintegrates on use. I have used it successfully in doing exactly the same job as you suggest when overcoming a tight Riley 9 steering box..
https://steamsupplies.com/collections/ti...g-compound
hth...
This is excellent stuff for this job, I second Hugh’s recommendation.
The gear will come off but you will likely require heat, a strong reinforced box section jig to hold the gear and a press.
