Poor brakes with no feeling
Further to Jim's comment above, silicone fluid differs from conventional ethylene glycol based fluids in that it is not hygroscopic. At first sight this might appear to be an advantage, however if any water does get into the system, rather than being 'absorbed' into the fluid where corrosion inhibitors can do their stuff, it forms separate globules in the brake lines which may cause localised corrosion spots (not to mention vapour locks, should you succeed in generating enough heat). Either way inspection of your wheel cylinder pistons sounds like a good idea.
Poor brakes with no feeling - by shane - 03-02-2020, 02:06 AM
RE: Poor brakes with no feeling - by Ian Williams - 03-02-2020, 06:18 AM
RE: Poor brakes with no feeling - by Tony Press - 03-02-2020, 06:37 AM
RE: Poor brakes with no feeling - by bob46320 - 03-02-2020, 07:49 AM
RE: Poor brakes with no feeling - by Steve kay - 03-02-2020, 07:55 AM
RE: Poor brakes with no feeling - by Chris KC - 03-02-2020, 08:28 AM
RE: Poor brakes with no feeling - by AustinWood - 03-02-2020, 10:02 AM
RE: Poor brakes with no feeling - by Charles P - 03-02-2020, 10:07 AM
RE: Poor brakes with no feeling - by Chris KC - 03-02-2020, 10:34 AM
RE: Poor brakes with no feeling - by Stuart Giles - 03-02-2020, 02:19 PM
RE: Poor brakes with no feeling - by Zetomagneto - 03-02-2020, 11:58 PM
RE: Poor brakes with no feeling - by Stuart Giles - 04-02-2020, 11:36 AM
RE: Poor brakes with no feeling - by Rogerfrench - 04-02-2020, 04:04 PM
RE: Poor brakes with no feeling - by Tony Press - 04-02-2020, 10:45 PM
RE: Poor brakes with no feeling - by Tony Press - 05-02-2020, 12:32 AM
RE: Poor brakes with no feeling - by Bob Culver - 05-02-2020, 01:37 AM
RE: Poor brakes with no feeling - by squeak - 05-02-2020, 01:52 AM
RE: Poor brakes with no feeling - by Rogerfrench - 05-02-2020, 04:35 PM
RE: Poor brakes with no feeling - by Terrytuned - 05-02-2020, 08:43 PM
RE: Poor brakes with no feeling - by Charles P - 05-02-2020, 09:32 PM
RE: Poor brakes with no feeling - by Rogerfrench - 06-02-2020, 02:34 PM
RE: Poor brakes with no feeling - by shane - 08-02-2020, 08:05 PM
RE: Poor brakes with no feeling - by Terrytuned - 08-02-2020, 08:44 PM
RE: Poor brakes with no feeling - by Colin Reed - 08-02-2020, 09:27 PM
RE: Poor brakes with no feeling - by Bob Culver - 08-02-2020, 09:44 PM
RE: Poor brakes with no feeling - by Reckless Rat - 08-02-2020, 09:48 PM
RE: Poor brakes with no feeling - by AustinWood - 08-02-2020, 10:57 PM
RE: Poor brakes with no feeling - by Bill Sheehan - 15-02-2020, 12:02 AM
RE: Poor brakes with no feeling - by AustinWood - 15-02-2020, 12:10 PM
