  • 3 Vote(s) - 4 Average
Building a Special Body
Hi Tom, I do have a couple of the threaded type, but in honesty have hardly used them, I understand your reasoning and can see how your suggestion would work. However I have up to now found that I can control any creep by replacing either every 3rd or 5th Cleco with rivets, this seems sufficient to lock things into place before riveting the rest.
Renaud, if you try searching "skin pin" you should get images of most varieties, the aircraft trade is the place to find all riveting supplies of the type I have been using on this build and as Tom described.
Building a Special Body - by Ian Williams - 12-10-2017, 03:46 AM
RE: Building a Special Body - by Charles P - 12-10-2017, 08:14 AM
RE: Building a Special Body - by Ruairidh Dunford - 12-10-2017, 08:44 AM
RE: Building a Special Body - by Dave Wortley - 12-10-2017, 09:42 AM
RE: Building a Special Body - by Ruairidh Dunford - 12-10-2017, 10:00 AM
RE: Building a Special Body - by Ian Williams - 12-10-2017, 10:07 AM
RE: Building a Special Body - by Mark Atkinson - 12-10-2017, 09:04 PM
RE: Building a Special Body - by Timothy P - 12-10-2017, 10:54 PM
RE: Building a Special Body - by Erich - 14-10-2017, 03:23 PM
RE: Building a Special Body - by Ian Williams - 15-10-2017, 03:46 AM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 01:52 AM
RE: Building a Special Body - by Erich - 01-11-2017, 05:02 PM
RE: Building a Special Body - by Duncan Grimmond - 01-11-2017, 05:28 PM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 08:03 PM
RE: Building a Special Body - by Duncan Grimmond - 01-11-2017, 10:00 PM
RE: Building a Special Body - by Ian Williams - 01-11-2017, 11:09 PM
RE: Building a Special Body - by Erich - 01-11-2017, 11:55 PM
RE: Building a Special Body - by Ian Williams - 02-11-2017, 03:38 AM
RE: Building a Special Body - by Timothy P - 02-11-2017, 05:43 PM
RE: Building a Special Body - by Ian Williams - 02-11-2017, 08:03 PM
RE: Building a Special Body - by Timothy P - 02-11-2017, 08:43 PM
RE: Building a Special Body - by Duncan Grimmond - 03-11-2017, 09:42 AM
RE: Building a Special Body - by Albert S - 04-11-2017, 09:56 AM
RE: Building a Special Body - by Ian Williams - 04-11-2017, 08:49 PM
RE: Building a Special Body - by Ian Williams - 06-02-2018, 08:58 PM
RE: Building a Special Body - by JonE - 06-02-2018, 11:30 PM
RE: Building a Special Body - by Erich - 07-02-2018, 04:53 AM
RE: Building a Special Body - by merlinart - 07-02-2018, 10:17 AM
RE: Building a Special Body - by Ian Williams - 09-02-2018, 09:14 PM
RE: Building a Special Body - by John Bonnett - 11-02-2018, 09:59 AM
RE: Building a Special Body - by Ian Williams - 11-02-2018, 09:07 PM
RE: Building a Special Body - by Nick Turley - 11-02-2018, 02:36 PM
RE: Building a Special Body - by Duncan Grimmond - 11-02-2018, 04:29 PM
RE: Building a Special Body - by John Bonnett - 12-02-2018, 08:46 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 09:00 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 09:26 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 09:42 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 10:02 AM
RE: Building a Special Body - by cardiffrob - 12-02-2018, 11:06 AM
RE: Building a Special Body - by Ian Williams - 12-02-2018, 10:49 PM
RE: Building a Special Body - by Charles P - 13-02-2018, 07:07 AM
RE: Building a Special Body - by Ian Williams - 20-02-2018, 01:45 AM
RE: Building a Special Body - by John Bonnett - 20-02-2018, 08:44 AM
RE: Building a Special Body - by Ian Williams - 20-02-2018, 08:09 PM
RE: Building a Special Body - by Ian Williams - 30-06-2018, 12:43 AM
RE: Building a Special Body - by Jamie - 30-06-2018, 08:49 AM
RE: Building a Special Body - by jansens - 02-07-2018, 06:44 PM
RE: Building a Special Body - by Duncan Grimmond - 02-07-2018, 07:20 PM
RE: Building a Special Body - by jansens - 03-07-2018, 12:19 AM
RE: Building a Special Body - by Ian Williams - 03-07-2018, 08:53 AM
RE: Building a Special Body - by Belinni - 08-04-2019, 12:37 PM
RE: Building a Special Body - by Ian Williams - 08-04-2019, 08:35 PM
RE: Building a Special Body - by squeak - 09-04-2019, 12:40 AM
RE: Building a Special Body - by Timothy P - 09-04-2019, 09:49 AM
RE: Building a Special Body - by Mark Atkinson - 09-04-2019, 10:07 AM
RE: Building a Special Body - by Belinni - 10-04-2019, 12:52 PM
RE: Building a Special Body - by Ian Williams - 18-05-2019, 05:54 AM
RE: Building a Special Body - by DavidL - 19-05-2019, 04:58 PM
RE: Building a Special Body - by Jays - 19-05-2019, 08:47 PM
RE: Building a Special Body - by Ian Williams - 20-05-2019, 05:03 AM
RE: Building a Special Body - by Ian Williams - 17-07-2019, 05:43 AM
RE: Building a Special Body - by Howard Wright - 17-07-2019, 07:37 AM
RE: Building a Special Body - by Ian Williams - 17-07-2019, 09:25 PM
RE: Building a Special Body - by Tony Press - 18-07-2019, 07:45 AM
RE: Building a Special Body - by Ian Williams - 23-07-2019, 03:05 AM
RE: Building a Special Body - by JonE - 23-07-2019, 08:45 PM
RE: Building a Special Body - by Ian Williams - 23-07-2019, 09:39 PM
RE: Building a Special Body - by Jamie - 24-07-2019, 07:34 AM
RE: Building a Special Body - by goodwoodweirdo - 24-07-2019, 02:53 PM
RE: Building a Special Body - by Ian Williams - 24-07-2019, 09:34 PM
RE: Building a Special Body - by Ian Williams - 26-07-2019, 04:34 AM
RE: Building a Special Body - by goodwoodweirdo - 29-07-2019, 03:50 PM
RE: Building a Special Body - by Chris KC - 05-08-2019, 08:21 PM
RE: Building a Special Body - by Ian Williams - 15-08-2019, 02:27 AM
RE: Building a Special Body - by Howard Wright - 15-08-2019, 07:23 AM
RE: Building a Special Body - by Ian Williams - 15-08-2019, 08:09 AM
RE: Building a Special Body - by Ian Williams - 24-08-2019, 09:52 PM
RE: Building a Special Body - by Ian Williams - 31-08-2019, 04:38 AM
RE: Building a Special Body - by Duncan Grimmond - 31-08-2019, 08:20 AM
RE: Building a Special Body - by Steve Bryant - 31-08-2019, 02:00 PM
RE: Building a Special Body - by wild_willy - 01-09-2019, 01:18 AM
RE: Building a Special Body - by Ian Williams - 01-09-2019, 01:52 AM
RE: Building a Special Body - by Jeff Taylor - 01-09-2019, 11:21 AM
RE: Building a Special Body - by David.H - 01-09-2019, 11:35 AM
RE: Building a Special Body - by wild_willy - 01-09-2019, 12:43 PM
RE: Building a Special Body - by Ian Williams - 01-12-2019, 02:14 AM
RE: Building a Special Body - by Paul N-M - 01-12-2019, 02:13 PM
RE: Building a Special Body - by Steve Bryant - 02-12-2019, 02:56 PM
RE: Building a Special Body - by sebring115 - 02-12-2019, 04:13 PM
RE: Building a Special Body - by Ian Williams - 03-12-2019, 08:35 PM
RE: Building a Special Body - by Peter Naulls - 03-12-2019, 10:07 PM
RE: Building a Special Body - by vintage_racing - 04-12-2019, 09:55 AM
RE: Building a Special Body - by Ian Williams - 04-12-2019, 08:05 PM
RE: Building a Special Body - by Peter Naulls - 04-12-2019, 09:35 PM
RE: Building a Special Body - by sebring115 - 05-12-2019, 11:03 AM
RE: Building a Special Body - by Renaud - 08-12-2019, 01:43 PM
RE: Building a Special Body - by Ian Williams - 08-12-2019, 08:52 PM
RE: Building a Special Body - by Renaud - 10-12-2019, 06:44 PM
RE: Building a Special Body - by Ian Williams - 10-12-2019, 07:46 PM
RE: Building a Special Body - by Reckless Rat - 10-12-2019, 08:45 PM
RE: Building a Special Body - by Renaud - 11-12-2019, 09:24 AM
RE: Building a Special Body - by Reckless Rat - 11-12-2019, 11:54 AM
RE: Building a Special Body - by Ian Williams - 11-12-2019, 11:46 PM
RE: Building a Special Body - by Duncan Grimmond - 12-12-2019, 03:15 PM
RE: Building a Special Body - by Renaud - 12-12-2019, 06:43 PM
RE: Building a Special Body - by Charles P - 12-12-2019, 07:34 PM
RE: Building a Special Body - by Reckless Rat - 12-12-2019, 08:29 PM
RE: Building a Special Body - by Ian Williams - 12-12-2019, 10:40 PM
RE: Building a Special Body - by Reckless Rat - 13-12-2019, 08:55 AM
RE: Building a Special Body - by Steve Bryant - 13-12-2019, 03:51 PM
RE: Building a Special Body - by Ian Williams - 13-01-2020, 01:17 AM
RE: Building a Special Body - by Duncan Grimmond - 13-01-2020, 09:09 AM
RE: Building a Special Body - by Hentzant - 13-01-2020, 11:20 AM
RE: Building a Special Body - by Duncan Grimmond - 13-01-2020, 07:00 PM
RE: Building a Special Body - by jansens - 15-01-2020, 07:51 PM
RE: Building a Special Body - by Ian Williams - 24-01-2020, 10:17 AM
RE: Building a Special Body - by Ian Williams - 26-01-2020, 08:07 AM
RE: Building a Special Body - by Duncan Grimmond - 27-01-2020, 09:21 AM
RE: Building a Special Body - by Tony Betts - 27-01-2020, 11:41 AM
RE: Building a Special Body - by jansens - 27-01-2020, 09:25 PM
RE: Building a Special Body - by Ian Williams - 27-01-2020, 09:25 PM
RE: Building a Special Body - by Renaud - 28-01-2020, 07:34 AM
RE: Building a Special Body - by jansens - 28-01-2020, 08:04 AM
RE: Building a Special Body - by Bobski - 28-01-2020, 10:25 AM
RE: Building a Special Body - by Charles P - 28-01-2020, 12:03 PM
RE: Building a Special Body - by Paul N-M - 28-01-2020, 06:37 PM
RE: Building a Special Body - by Ian Williams - 28-01-2020, 09:05 PM
RE: Building a Special Body - by Renaud - 30-01-2020, 07:22 PM
RE: Building a Special Body - by Ian Williams - 30-01-2020, 07:42 PM
RE: Building a Special Body - by Ian Williams - 05-04-2020, 03:55 AM
RE: Building a Special Body - by Spex - 05-04-2020, 06:24 AM
RE: Building a Special Body - by Ian Williams - 05-04-2020, 08:07 AM
RE: Building a Special Body - by Renaud - 05-04-2020, 08:19 AM
RE: Building a Special Body - by Ian Williams - 10-04-2020, 02:29 AM
RE: Building a Special Body - by Renaud - 10-04-2020, 12:44 PM
RE: Building a Special Body - by flywheel1935 - 10-04-2020, 01:05 PM
RE: Building a Special Body - by Paul N-M - 11-04-2020, 08:34 AM
RE: Building a Special Body - by flywheel1935 - 11-04-2020, 10:19 AM
RE: Building a Special Body - by Paul N-M - 11-04-2020, 10:59 AM
RE: Building a Special Body - by Peter Sweeney - 11-04-2020, 11:30 AM
RE: Building a Special Body - by Cliff Ringrose - 11-04-2020, 04:10 PM
RE: Building a Special Body - by Ian Williams - 14-04-2020, 07:03 AM
RE: Building a Special Body - by flywheel1935 - 14-04-2020, 11:08 AM
RE: Building a Special Body - by Bruce Nicholls - 16-04-2020, 05:06 PM
RE: Building a Special Body - by Ian Williams - 21-04-2020, 01:51 AM
RE: Building a Special Body - by Tony Press - 21-04-2020, 02:15 AM
RE: Building a Special Body - by Renaud - 21-04-2020, 07:26 AM
RE: Building a Special Body - by Ian Williams - 21-04-2020, 10:39 AM
RE: Building a Special Body - by Renaud - 21-04-2020, 12:57 PM
RE: Building a Special Body - by Ian Williams - 23-04-2020, 02:57 AM
RE: Building a Special Body - by Ivor Hawkins - 23-04-2020, 08:39 AM
RE: Building a Special Body - by Ian Williams - 24-04-2020, 11:11 PM
RE: Building a Special Body - by Ian Williams - 25-04-2020, 05:12 AM
RE: Building a Special Body - by jpsmit - 25-04-2020, 02:35 PM
RE: Building a Special Body - by Peter Naulls - 25-04-2020, 09:43 PM
RE: Building a Special Body - by Ian Williams - 25-04-2020, 09:56 PM
RE: Building a Special Body - by Steve Bryant - 01-01-2023, 11:21 PM
RE: Building a Special Body - by Ian Williams - 02-01-2023, 08:10 AM
