29-01-2020, 12:56 PM
(This post was last modified: 29-01-2020, 01:07 PM by Howard Wright.)
Hi Adam
The slow running adjusting device is often split. I soldered the slit up on mine and it improved running no end. Willie MacKenzie sells a new adjuster, he also does the main and compensating jets.
You should get a copy of “Hints on Fitting and Adjusting Zenith Carburetter” David Cochrane sells a reproduction of this little booklet. It helped me a lot!
Hi Adam
Willie also sells floats, needle valves and bob weights for the float chamber.
Hi Adam
