21-01-2020, 05:29 PM
(This post was last modified: 21-01-2020, 05:46 PM by Dennis Nicholas.)
No heater yet?
Don't tell anyone but I used Morris Minor 1,000 drop arms with the tapered ends turned down parallel and keyway cut in to fit in the (big 7) stub axles. The arms had to be bent downwards and up to form a mild Z shape so track rod would clear sump/chassis....the advantage was easy to source MM ball joint track rod ends, right and left hand threaded and the arms will not twist in the stubs. Work done by local garage long time ago.....fix anything from TVs to combine harvesters
