Valve guides
If your block is 54 something then they will be stepped guides.You will also have screw in core plugs on an earlier block although I have seen screw in core plugs with straight guides.
Easiest way to tell is to knock one out with a drift .
Valve guides - by Spex - 20-01-2020, 09:36 PM
RE: Valve guides - by Tony Betts - 20-01-2020, 10:11 PM
RE: Valve guides - by Spex - 20-01-2020, 11:38 PM
RE: Valve guides - by Zetomagneto - 20-01-2020, 11:49 PM
RE: Valve guides - by Spex - 21-01-2020, 12:52 AM
